07-16-2008, 04:16 PM
Re: Wiring problems: coil
Mitsu Booster
My Ride: '85 Plymouth Horizon
Engine: 2.5L TII
Hey thanks for the help. I checked all the fuses and they seem to be good but I have done some more troubleshooting and found some other surprises. I measured the voltage across all the computer/sensor grounds and they're all the same including the negative coil wire (detached from the coil), they all give a reading of 5.4v +/-.1v but when I measure between the ground cable and the body there is a reading of 0 (which would make sense). I also found there to be 0v in the circuits within the car (except the cluster negatives) which leads me to believe it has to be in the wiring harness itself and not anything just touching the body. I now have 95% of the engine wiring harness ripped apart and found that when I turn the ignition off and the computer stays on b/c of the 5.4v holding the ASD, if I remove the o2 sensor the ASD shuts off immediately. I tried turning the computer on after without the o2 sensor plugged in and read +12v on the coil negative wire along with all the other computer grounds just like before but when i turned the ign. off the thing shut off right away like it should. There is continuity between the + & - (source from ASD and ground) in the o2 sensor, I'm not sure if this is supposed to be or not but it would make an obvious short if it isn't to be this way. But i'm still not convinced that it's the o2 sensor thats the problem, i think it's just a strange coincidence since there is still a short to ground when the computer/ASD is on. With the fault codes I haven't checked, I don't think i can since my computer will stay on unless i have the o2 pulled or cut the power supply. oh I have a wiring diagram for the motor too, should I post it?
mopar to ya!
