Old 04-20-2003, 08:57 PM   #1
odometer
getragguy
i was wondering what possible problems could cause the odometer to not work. my speedo,tach and everthing else works on the instrument panel.
Old 04-20-2003, 09:11 PM   #2
Might be a loose wire from the speed sensor.
ShelbyTurbo is offline
Old 04-20-2003, 09:12 PM   #3
<----------- Want to use the picture of your boost gauge for your avitar?
Old 04-20-2003, 09:13 PM   #4
getragguy
no, even though it is my boost guage, i'll use the speedo.
Old 04-22-2003, 09:36 AM   #5
newtomopar
I am having the exact same problem. Did you figure it out? If so, what was it?
Old 04-22-2003, 10:35 AM   #6
getragguy
I havn't gotten it fixed yet. but... I did take the instrument cluster out and clean the connections. I found some dead bulbs.lol and some corrosion. Shelbyturbo has got an extra instrument cluster I am going to try. let you know after that. BTW: what kind of car do your drive?
Old 04-22-2003, 04:33 PM   #7
newtomopar
'90 Daytona 2.5L Turbo. Just got it. My first mopar and my first turbo. A lot of fun so far and I am planning on doing some upgrades to have more fun.
Old 05-01-2003, 03:37 PM   #8
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (20)
Mine HAD the same problerm, here is what I did:
I took mine appart yesterday- an 88 gtc convertible. I removed the speedo from the cluster, in the back of the unit I removed about 6-8 screws total, they are little silver ones. There is a small motor (glued to a small board) on the side of the speedo that is held on by 2 screws- take them out and look for crap on the little gears. Mine had what appeared to be a little gear tooth that broke off- but I was unable to see were it came from. I removed it , reassembled and all is good now.
crazymadbastard is offline
Old 05-01-2003, 04:53 PM   #9
getragguy
Thanks allot for your help, I'll have to try that when I get my car running again. The turbo (hopefully) took a huge **** and it makes an incredible knocking noise. looking forward to tearing my engine apart.
Old 05-01-2003, 05:29 PM   #10
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (20)
I guess a working speedo would be worthless w/o an engine = (
Old 05-03-2003, 08:59 PM   #11
newtomopar
I took my cluster apart anda got down to the speedo, however it appeared to be held in by three gray wires. I was unable to get the speedo out more than an inch due to these wires. Any ideas? Did you see the same thing?
Old 05-04-2003, 08:40 PM   #12
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (20)
yeah, that's all I did, I worked the little side motor out a bit and was able to find the offending piece of plastic clogging up the gears. Unless you mean that the whole speedo is still in the cluster, then you have to pull the speedo out entirely from the rest of the cluster. there are 3 pins that attach to the speedo by friction, just pull the speedo out. I also used tv tuner cleaner from radio shack to clean and lube the gears up.
Free Online RPG | Personal Loans | Credit Card | Loans | Mortgage Calculator
Page generated in 0.72307 seconds with 13 queries
