Old 07-17-2008, 11:50 PM   #1
O2 gauge wrong??
My Ride: 1986 Daytona TurboZ
Engine: 2.2 Turbo 1
i have a stock 86 Daytona T1. i just installed a O2 gauge and it dosent seem to be working correctly. i have it grounded to the engine as it should be.
at idle and wile normal driving it crosses over from ideal to lean and back and fourth as i understand it should, when i go to WOT it seems do allways go verry lean. could a bad TPS cause this? i have a code 24 and my limmited power light is on. i almost have all the parts and i plan on converting it to a T2 with GLHS electronics. but i want to make sure my 02 gauge is working correctly before. any input would help
Ryan2112 is offline
Old 07-18-2008, 12:10 AM   #2
Re: O2 gauge wrong??
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
Check your tps, if you part throttle it could be, not saying its the answer
check your throttle maximum!!
speeduphoria is offline
Old 07-18-2008, 07:53 PM   #3
dont trust a narrowband gauge... they're useless.
try reading the plugs to see where afrs are at whatever load points or get a wideband
ComputerJLT is offline
Old 07-18-2008, 09:21 PM   #4
My Ride: 85 GLHT, 87 ShelbyZ
O2 gauge should be soldered and grounded to the battery. Fix the TPS for sure! After you get it running right get a wideband O2 setup. The Narrowband O2 gauges/sensors are just to keep the catalytic converter happy. They're NOT to be used to make sure you're safe at WOT. The LC-1 from Innovate will give you that accuracy and has a Narrowband output you can feed to the ECU and eliminate the factory O2 completely.
GLHNSLHT2 is offline
Duwayne Burnside | Mortgage | Freelance | Mortgage Calculator | Loans
Page generated in 0.25947 seconds with 13 queries
