Old 04-21-2003, 11:36 PM   #1
Turbo Timers?
T1OmniIC
Alright, i know that i am supposed to leave the car running for a few minutes after i drive it so that it can cool down a wee bit.
I also know that it pissed me off to have to sit in my car for 3 minutes while it cools down before i shut it off.
Now, a lot of my friends with turboed Japanese/European cars seem to like these widgets called 'Turbo-Timers'. They leave your car running after you shut it off for a few minutes so you don't have to wait around in the car. This seems neat! Does anyone else use one? What is a good model, and are they difficult to install in a TD?
Thanks!
-Aston
Old 04-23-2003, 11:55 PM   #2
My Ride: 92 Iroc R/T
I have an older Apexi Turbo Timer. I like it. Real easy to install. Only 3 wires. Some of the new timers like Apexi and HKS have some neat features like air/fuel readout, voltage readout and built in G tech...
Shadona is offline
Old 04-23-2003, 11:58 PM   #3
i have an HKS Type-0 timer. took awhile to install cuz of the lack of a harness conector, but it works like a charm. has a 'wow' factor too.
BuRn__ is offline
Old 04-24-2003, 12:39 AM   #4
Show me your g-valve
Lebaronguy2001's Avatar
My Ride: '89Baron, '04Stratus
Images: 19
maybe this is defferent for different timers, btu what wires do these timers hook into....i dont quite understand how it keeps the car running when the key is turned off....
Lebaronguy2001 is offline
Old 04-24-2003, 01:02 AM   #5
i'm pretty positive it's an ignition wire, but i've never hooked one up, just using common sense
89daytonaTII is offline
Old 04-24-2003, 01:38 AM   #6
the timer has a wire that taps the ignition wire. it keeps sending a signal to the wire that keeps the car running (only if the parking brake is enabled though). and when the timer hits 0, it no longer sends a signal, thus shutting the car off.
BuRn__ is offline
Old 04-24-2003, 10:28 PM   #7
T1OmniIC
Sweet. I just might have to invest in one of these things. Sounds like a good idea!
-Aston
Hotels | Debt Management | TurboTax | New York Hotel | Facebook Proxy
Page generated in 0.27438 seconds with 13 queries
