Old 04-24-2003, 03:36 PM   #1
How far can +40 injectors take you with...
a 3-bar MAP/+40 custom calibration on a 2.5 liter? Just curious if anybody knows a rough estimate of this. I'm currently running around 20psi of boost. Thanks.
Christian J. Grest
BUBBA is offline
Old 04-24-2003, 07:55 PM   #2
My Ride: 86 SC & 98 Neon
1/4: 9.900
With race fuel a rough max estimate may be 22 psi, with street fuel 18-19. lots of other variiables like how much air you're flowing, puel pump, intercooler, etc.
DblTrbl is offline
Old 04-24-2003, 08:19 PM   #3
My Ride: 88 Lancer Shelby
Engine: 4cyl. 2.5L
I ran 20psi on a stock fuel system, ex. AFPR, on 20%'s.
LancerShelby is offline
Old 04-24-2003, 10:03 PM   #4
mwadams's Avatar
My Ride: 87 GLHS
Engine: 2.5 T2
I'm also running 20psi w/ +20's w/o a problem on 2.5. I would think +40's would take you at least to 25psi or more
mwadams is offline
Old 04-24-2003, 11:15 PM   #5
My Ride: 1985 Shelby Charger
Engine: 2.2 T2
The +40/52lb injectors are good for 300hp @ 80% duty cycle.
Click here
crazy1eye is offline
Old 04-25-2003, 08:20 AM   #6
My Ride: 1987 Shelby GLHS 189
Click here
I've seen a 3 bar map 2.5L set-up make 340 hp and 388 ft lbs... all on 93 octane pump gas at 25 psi boost.
glhsken is offline
Old 04-25-2003, 09:16 AM   #7
How the heck are you doing all of that on pump gas? That's really impressive.
Christian J. Grest
BUBBA is offline
Old 04-25-2003, 09:23 AM   #8
My Ride: 1991 Spirit R/T
Christian J. Grest
Same way this car did this with +40's, stock ECU, and olnly 35 psi base fuel pressure! Its still pig rich up top!
You can make alot of power with +40's.
4sfed4 is offline
Old 04-25-2003, 09:48 AM   #9
Hey Larry, what's with the big dip around 5800 rpm on that chart?
lametec is offline
Old 04-25-2003, 09:52 AM   #10
The wastegate going bonkers!!!!
4sfed4 is offline
Old 04-25-2003, 09:55 AM   #11
The 16v lifters started chattering
glhsken is offline
Old 04-25-2003, 09:56 AM   #12
Christian J. Grest
With a calibration from someone who really knows his stuff.
glhsken is offline
Old 04-25-2003, 09:58 AM   #13
More misinformation from those with "16V envy"!!!!
No lifter chatter on my car!
4sfed4 is offline
Old 04-25-2003, 10:06 AM   #14
My Ride: '04 SRT-4, '87 CSX
Engine: 2.4L I4
Was that with a RRR, too?
CSX321 is offline
Old 04-25-2003, 10:57 AM   #15
Nope.
4sfed4 is offline
Best Credit Cards | Loans | Ringtones | Credit Cards | Mortgages
Page generated in 0.56660 seconds with 14 queries
