Old 08-08-2008, 12:13 PM   #1
2.5 T1 Conversion
My Ride: Daytona
Who has done a 2.5 T1 conversion to a T2? What did you use for SMEC Calibrations?
Redcar is offline
Old 08-08-2008, 02:03 PM   #2
Re: 2.5 T1 Conversion
Hybrid Booster
My Ride: 87 Shelby Z
Engine: 88 2.2 T2
I've done it. Got a calibration from cindy at fwd performance. All that you have to do is add an intercooler, iat sensor, calibration, and your choice of turbo.
moparfreak3 is offline
Old 08-08-2008, 02:14 PM   #3
My Ride: Daytona
What stage did you get from FDW? Did you change your injector size or get a three bar MAP? What boost are you running? Do you like it? What don't you like about it?
Redcar is offline
Old 08-08-2008, 02:21 PM   #4
Hybrid Booster
Engine: 88 2.2 T2
I kept my stock map sensor and stock 33pph injectors. I got a stage 3 and had cindy take out the overboost shutdown so I could run just a little more boost. I loved it had no complaints at all. It ran great had alot better pickup than stock. She can make the computer special to your setup. I kept the stock mitsubishi turbo on mine and was running 17 lbs of boost. If you go over 15 with the stock injectors and map sensor you just need to watch your afr to make sure you don't lean out. I was also running an mbc instead of the computer controlled solenoid.
Old 08-08-2008, 06:38 PM   #5
My Ride: Daytona
Any one use a garrett turbo? What about a super 60 computer?
Redcar is offline
Old 08-08-2008, 09:08 PM   #6
Hybrid Booster
Engine: 88 2.2 T2
you could do it with a garrett as well would not matter a whole lot. As far as the super 60 computer it is calibrated to be used with the super 60 package (head, turbo, cam, 3 bar map and +40 injectors. You are better off just having one made for your application.
Magazine Subscriptions | Compare | Turbo Tax software | Israel Hotels | Turbo Tax
Page generated in 0.53860 seconds with 13 queries
