Old 04-25-2003, 03:14 AM   #1
BIG injectors?
My Ride: 1985 Shelby Charger
Engine: 2.2 T2
Is anyone using injectors larger than 52lb? If so, what size? What fuel rail psi? Brand?
I know the 52lb injectors can probably handle 350hp, but at what duty cycle, 100%??? With my new setup, I'm hoping to make more than 350hp & would rather be safe than sorry when it comes to the injector size, so, I'm considering 65lb or even 72lb Delphi injectors(rated @ 43.5psi). Now, there's 2 ways of doing this, 1, use the 65lb injectors at our stock 55psi, in turn making them 73lb injectors, perfect. 2, using the 72lb injectors & have the custom cal set for 43.5 fuel rail psi. But now, those 72lb injectors won't easily support 400hp because I've lowered the base fuel psi. But, I do like the fact of running a lower base fuel psi, that way, when you run 25+ boost, your fuel psi won't be 80+psi, therefor putting less strain on your fuel system.
Injector tech
I know, I know... blah, blah, blah, fuel psi... blah, blah, blah, injectors
What do you think?
Thanks
PS: Our injectors are low impudence, right?
crazy1eye is offline
Old 04-25-2003, 08:27 AM   #2
My Ride: 1987 Shelby GLHS 189
Pat,
James is looking at 72's...
With a custom cal, you could still have 55 psi base pressure. The calibration takes injector size into account and varies duty cycle. So the idle would be fine. There is 1 car I know of with that exact set-up.. of course this car likes 35 psi of boost.
yes, low
glhsken is offline
Old 04-25-2003, 11:28 AM   #3
Engine: 2.2 T2
Just remember, most injectors are sold with a flow rating @ 43.5 base fuel rail psi. So, a set of 72lb injectors would now be 81lb injectors @ 55psi... Which is OK
Old 04-25-2003, 12:02 PM   #4
Good point... so when the time comes to "step-up". More than likely worth a few extra $$$ to have them flowed at the pressure you intend to use.
glhsken is offline
Old 04-25-2003, 01:20 PM   #5
Engine: 2.2 T2
There's no reason to have them flowed, it's a simple calculation.
square root of new psi(55) / old psi(43.5) x old injector rate(72) = new injector rate(81).
55 / 43.5 = 1.264
sqrt of 1.264 = 1.124
1.124 x 72 = 80.96
Myspace Layouts | Credit Counseling | Mortgage Calculator | Myspace Proxy Directory | Mortgage Loans
Page generated in 0.30871 seconds with 13 queries
