Old 08-27-2008, 01:00 AM   #1
Innovate LMA-3 or DL-32 users I need some help!
My Ride: 85 GLHT, 87 ShelbyZ
I just got my DL-32 hooked up a little. How are people hooking up the rpm inputs? I'd like to try and not have to buy an inductive clamp or the rpm converter(not even sure how that works). Can I wire it to the positive and negative of the coil?
Thanks!
GLHNSLHT2 is offline
Old 09-07-2008, 04:33 PM   #2
Re: Innovate LMA-3 or DL-32 users I need some help!
My Ride: '88 Horizon R/T
Engine: 2.4L DOHC
The safest way to do this would be to tap the tachometer output wire from your SMEC. It's a Grey/Lt Blue wire that goes to your instrument cluster. It's a basic pulsed signal that anything should be able to read without the crazy flyback voltages you'll encounter at the coil.
UnaClocker is offline
Old 09-07-2008, 08:38 PM   #3
Thanks brian. I got that suggestion at the other site a day after posting. Tried it, seems to be working.
Secured Loans | Secured Loans | Credit Cards | Debt Help | Loans
Page generated in 0.37430 seconds with 13 queries
