10-06-2008, 01:14 PM
#20
Re: more problems
My Ride: 89+90 Daytona Shelby
Engine: 2.2 TII, 2.5 TI
You sure the noise is coming from the valvetrain? Could be a wrist pin rattle. Did you use new rods or used ones?
As for the compression, did you go through the full break-in procedure? What I do is let the engine warm up on first start and set the timing. Go to an open highway and take it up to 55, then let it slow down to 35 in third gear. Do that a few times. Take it back, drain the oil, then drive it normally for about 500 miles or so. Not too much highway, no beating on it, not too much idling. If you don't get the rings to seat properly, it'll always burn oil no matter what you do. On a new rebuild you should have minimum 130 PSI across the board (although I'd expect up to 150). 90 is the wear limit for an old engine. Not good.
