Old 05-01-2003, 05:34 AM   #1
Upgrade comptuer?
do i need to upgrade with my computer to handle a super 60 or t3/t4 at 14psi, or get a 3 bar map?
i have a 1991 daytona shelby 2.5 TI
thanks!
unclejemima is offline
Old 05-01-2003, 12:29 PM   #2
My Ride: Titan & '89 C/S AGS
Engine: 2.5L T1
To handle any turbo (S60, T3/T4, or even Mitsu) at 14psi, you will have to have a custom cal done as the stock T1 in '90 and '91 hits overboost at 13.6psi (well, you could diode the map sensor). You don't need a 3-bar map to run 14psi, though. If you want to run more than ~14.5psi, then you'll need a 3-bar map and acustom cal to accomodate it. The 3-bar map is good for ~29psi.
Shel-Game is offline
Old 05-01-2003, 12:34 PM   #3
Hmm, i've run my stock 89' 2.5 cal, using a diode for MAP cutout, +40 injectors(31-33psi fuel pressure), and a grainger valve, at 20psi of boost. Actually ran pretty good that way too.
Christian J. Grest
BUBBA is offline
Old 05-02-2003, 06:30 PM   #4
My Ride: 86 SC & 98 Neon
1/4: 9.900
I still use the stock T1 computer. Custom cal is probably simpler, but I already built the 3to1 RRR/AFPR and zener diode.
DblTrbl is offline
Old 05-02-2003, 08:38 PM   #5
Re: Upgrade comptuer?
My Ride: 88 Lancer Shelby
Engine: 4cyl. 2.5L
thanks!
No. The stock cut-out is 14.5psi. The computer doesn't care what turbo is on there, just how much air the engine is getting.
LancerShelby is offline
Old 05-02-2003, 10:35 PM   #6
Engine: 2.5L T1
Acually, the stock cut-out is 13.6 psi on the '90/'91 T1. The MAP sensor will read to about 14.5, but the SBEC starts pulling spark at 13.6.
-Rob
Mortgage Calculator | Online Advertising | Online Loans | Cheap Car Insurance | Teen Chat
Page generated in 0.55856 seconds with 13 queries
