Old 05-04-2003, 11:58 PM   #1
ACCEL coil
90TurboShadow
i can get a ACCEL COIL for my car. ITS HUGE!!! universal i believe... would this work for my shadow??
Old 05-05-2003, 12:06 AM   #2
masterjr33-2
do you think the bigger the coil the beter? i guess the thicker the spark plug wires the more horse power they will add?
rethink your entusiasim.
yes it should work..
Old 05-05-2003, 12:13 AM   #3
The stock coil is more than adequate.
Besides those Accel coils are huge and impossible to mount close enough to the distributor cap.
ShelbyMotorspts is offline
Old 05-05-2003, 12:48 PM   #4
MrCSX55's Avatar
My Ride: 87 CSX #55
Engine: 89-2.2 c-block
If that is the big square looking coil a little warning on use. I had one in my CSX, for some reason it spiked my stock computer. It burnt my circuit board, AIS motor, and speed sensor. Cost me little over $200 to fix. My .02 cents worth.
Later
MrCSX55 is offline
Old 05-05-2003, 01:44 PM   #5
My Ride: 88 CSX-T
Engine: 2.2 T1
This is totally true. The stock ignition system is good to over 300hp. Just a good quality set of wires (such as Magnacore) is the best thing you can do.
Save your money.
csxt665 is offline
Old 05-05-2003, 03:02 PM   #6
My Ride: 88 CSX-T
Engine: 2.2 T1
I don't think you can shorten the wire per se... But I do know that when you buy a set of Accel universal wires, you cut to fit. But alas, I haven't found a set for our cars. Also, in some brands of exact fit wires, it comes /w/ 2 coil wires. One is shorter than the other. I have had this happen on quite a few occasions when getting a set from Autozone.
csxt665 is offline
Old 05-05-2003, 04:27 PM   #7
90TurboShadow
yeah its a pretty HUGE round Yellow ACCEL coil.. bro said it would work on mine.. but after u guys telling me the stock is good till 300... ill save my money n put it to some better use.. HOW CAN I SHORTEN MY COIL WIRE!?! i wanna put my coil closer to the cap to shorten the wire.. does this make a lil better spark?? plus how do i shorten this wire??
Loans | Advertising | Debt Help | Wep cracker | Myspace Proxy
Page generated in 0.31795 seconds with 13 queries
