Old 05-10-2003, 10:29 PM   #1
Turbo to the Turismo
My Ride: 1985 Shelby Charger
Engine: 2.2 T2/A568
Okay, I have an 85 SC parts car. Engine bay wiring is in really nice shape. I just want to know, since the turismo is an 85, will this engine bay wiring hook right up with enerything else? or wil i need to swap the wires under the dash too?
plymouthturismo2.2 is offline
Old 05-10-2003, 11:57 PM   #2
My Ride: 88 Plymouth Reliant
Engine: 2.5L T2
is the turismo carburated? if it is you might have to cut a hole in the pass side firewall (3") to get the logic module wiring through so you can mount the logic module in the kick panel. the firewall connector to the rest of the in car wiring should be the same. youll have to compare the connectors and the firewalls of the two cars to be sure itll work but it should. good luck
Brian.
PS im doing a 1988 smec swap in an omni glh (1984) so ill have to do some cutting and soldering or move a bunch of pins around on the firewall connector. yours should be easier.
Aries_Turbo is offline
Old 05-11-2003, 06:30 AM   #3
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
You won't have to mess with the underdash wiring except to add one wire for the in-tank fuel pump. If you convert to SMEC, you won't have to punch a 2.5" hole in the firewall for the LM wiring.
iTurbo is offline
Old 05-18-2003, 08:59 PM   #4
My Ride: 89 GTC Conv. REDTOP
Engine: intercooled 2.5
Feedback: (8)
Isn't this hobby fun?]
redbaron is offline
Credit Card | Ringtones | Loans | Free Advertising | Magazine Subscriptions
Page generated in 0.29172 seconds with 13 queries
