05-18-2003, 09:23 AM
Originally posted by 91DSX
Can I reattach the schrader valve to the rail after I'm done setting the FP, can you not still attach a gauge WITH the schrader valve still there? I ask this because I'm only going to use the gauge when I need to set the FP and the gauges are known to crack under vibration when left on the rail directly. BTW whats the inside diameter of the port since I've looked and realized an adapter is needed. Thanx!
Yes you can put the schrader valve back in when done, it is just like the valve stem on a tire.
No you cannot attach a gauge with the schrader valve in the rail, it's purpose is to stop the fuel from coming out untill it is depressed (again, like a tire).
The gauges are not known to crack, it is the rail itself. For well over a year I used the port via a line (-6 AN) and had no cracking issues. Now I am teed directly into the feed line for the main gauge and another mounted on the fpr for underhood.
