Old 05-15-2003, 08:13 PM   #1
Zener works part time?
Jambbii
After the car has been running for 10 minutes or so the cutout comes back. Sometimes it works and sometimes it cuts out. Bad zener? I can let the car sit for 30 minutes and it runs 14psi, then drive it around for a while then the cutout comes back. Oh yeah its the 84 on my sig.
Old 05-15-2003, 09:51 PM   #2
The zener voltage could be right on the edge of cutout, and when it gets "warm" it goes beyond.
lametec is offline
Old 05-16-2003, 03:39 PM   #3
Jambbii
So should I replace it? I have a 4.3 .5volt and it is a pain to get to.
Old 05-16-2003, 03:46 PM   #4
I'd try another one to see if it cures the problem.
lametec is offline
Old 05-18-2003, 12:26 AM   #5
My Ride: 86 SC & 98 Neon
1/4: 9.900
Sounds like you're on the hairy edge. It could also be that other thing like your computer or your map sensor is what is warming up and not the zener. A different zener maight solve the problem anyway it you happen to get one that's just a slight bit lower in voltage.
DblTrbl is offline
Ringtones | Mobile Phone | Ringtones | Loans | Personal Loans
Page generated in 0.35359 seconds with 13 queries
