12-02-2008, 04:05 PM
Re: DSM injectors bottom o-ring?
My Ride: 1988 CSX-T
There's no lip on the intake manifold, but the o-ring kind of wedges in pretty tight, and doesn't leak. I ran them in my csx-t for a while, with no sealing problems. Just be carefull when you remove them again though because sometimes the o-ring stays in the manifold and you have to grab a pick and pull it out. To get them in the rail was a pain though. I wrapped the tops in electrical tape and cut the top of the wrapped tape off to give the o-ring something to press against when you push them in the rail, otherwise the rings slip down the top of the injector..very annoying. Also, I had a starting problem sometimes. It would flood, and you'd have to wait a while then start it and floor it until it cleared out the cylinders.In case you don't know, if you have the 450 blue tops, they're the equivilant of 48lb injectors. Good luck.
