Old 11-21-2008, 01:18 PM   #1
3.0 v6 5speed duster looking for an engine management
My Ride: 93 plymoth sundance
Engine: 3.0 3g72
i have a 93 3.0 i am going to run a turbo but want to wire the engine management first. i want to get used to tuning it. what should i buy i want ignition and fuel management adjestable rev limiter and i would like a knock sensor. any ideas on what i should buy and where can i buy it
paduster is offline
Old 11-21-2008, 02:16 PM   #2
Re: 3.0 v6 5speed duster looking for an engine management
My Ride: 92 sundance duster
Engine: 3.0L 24v
Megasquirt-II version 3.0 (also get the relay board, stimulator, and an LC-1 WBo2 ) DIYAutoTune.com has everything, the computer, LC-1, GM sensors, labeled wires etc. Its what i am running on my 24v swap. not to mention just the MS-II and parts will probably only be around $350-$400 (LC-1 is ~$200 but worth it)
Shadow24V is offline
Old 11-22-2008, 02:24 PM   #3
Engine: 3.0 3g72
so about 600 dollors. how hard is it to build the thing
paduster is offline
Old 11-22-2008, 08:12 PM   #4
Engine: 3.0L 24v
took me about 8-9 hours total, over 3 days. you CAN buy a pre-assembled MS-II from DIYAutotune as well (surface mount v3.57 board and regular v3.0 boards). If your good with a soldering iron and got a decent magnifying glass, you'll do fine. take your time. the Stimulator is a must if your going to build it yourself. you use it to make sure the circuits are working fine as you assemble the MS. The LC-1 is a direct input to the MS, pre-configured settings are included.
btw, what are you going to do for spark? retain the distributor or go with (E)DIS? IIRC you should be able to use the distributor as usual, but im not 100% sure. my MS install isnt on a 12v lol
Old 11-24-2008, 12:53 AM   #5
Engine: 3.0 3g72
i think i will go with edis but not sure what to use is as the coils and from what was yours the gm coils or what did you use
paduster is offline
Old 11-24-2008, 10:17 AM   #6
Authorized TD Vendor
Usually you'd use Ford coils with EDIS, but it can work with the coil pack off Chrysler LH platform cars and later minivans as well.
A lot of the 3.0s used an optical trigger wheel with six equally spaced slots in the distributor. If you have one of these, our article on the 240SX would help with ignition control:
How to MegaSquirt your Nissan 240sx
Sounds like a weird thing, but Mopar and Nissan ordered their ignitions out of the same catalog.
Matt Cramer - Turbocharged '66 Dart
DIYAutoTune.com
Matt Cramer is offline
Old 11-24-2008, 12:50 PM   #7
Engine: 3.0 3g72
wow the only question i have now is when i buy all this stuff and go to build this i hope it comes with directions or i will be on here many times daily asking for help i think. this is going to be fun to try. i hope you all will help me. i am sure i will be asking
paduster is offline
Old 11-24-2008, 01:21 PM   #8
The directions are online, so you can look them up before buying:
MegaSquirt - Electronic Fuel Injection Computer by Bowling & Grippo * * Đ2005
DIYAutoTune.com
Old 11-24-2008, 01:22 PM   #9
My Ride: 1993 Iroc Daytona
Engine: 3.0 V6
Images: 2
m90daytona on here has done it on a 3.0 with a distributor. Ours works alot like the 240sx apparently. I wouldnt use EDIS i dont think. Not that its bad but i would probably keep the stock distributor setup myself probably.
irocelectric93 is offline
Old 11-24-2008, 09:38 PM   #10
Engine: 3.0 3g72
thanks that manual helps allot and is confussing at the same time.
i might use the dis. but not sure have to make dision later around income tax time when i buy this
paduster is offline
Old 11-25-2008, 04:03 PM   #11
Engine: 3.0L 24v
feel free to PM or post with questions. ill help out as much as i can
Old 11-25-2008, 10:40 PM   #12
Engine: 3.0 3g72
as soon as i get it i plan on it
paduster is offline
Mortgage Calculator | Problem Mortgage | Baby Bibs | Internet Advertising | Tour Management Software
Page generated in 0.64952 seconds with 13 queries
