Old 11-24-2008, 12:39 PM   #1
What computer to use
My Ride: 86 Chrysler Laser XE
I have a stock 86 chrysler Laser t1 log what computer can I run I want to run 14 psi it is basically stock... what mopar computer can I run... or I am open to anyother computer that is basically a drop in... any help would be grear
BoostedShelbyZ is offline
Old 11-24-2008, 04:00 PM   #2
Re: What computer to use
My Ride: 84 Turbo Z, more
Engine: 2.2-2.5
FWD Performance has just what you want.
4Daytonas is offline
Old 12-04-2008, 02:59 PM   #3
Be careful without using water injection. You are close or at the limit of boost without some type of intercooling. Honestly in your case as long as you raise boost 1 psi at a time and read the plugs your stock computer and a g-valve should work fine. Even with the performance computers I still prefer to use a g-valve and slowly raise the boost, this way if the computer cal is wrong you will not melt a piston.
Turbo84Voyager is offline
Loans | Cheap Hosting | Bad Credit Mortgages | Mortgage | Debt Consolidation
Page generated in 0.32929 seconds with 13 queries
