Old 05-30-2003, 06:57 PM   #1
No power to fuel pump
Gibbsalot
Is there a fuse for the Fuel Pump, or anyway I could power up my car with the fuel pump disconnected. I have my engine out in the shop, and im working on audio stuff, so I want power to the cab, but do not want fuel squirting out. Is the only plug on the fuel tank somewhere? or is there a fuse inside the cabin/trunk that I could just take out? Thanks!
Old 05-30-2003, 07:18 PM   #2
Yup, just pull the fuse. It's with the other fuses on the fuse panel.
ShelbyMotorspts is offline
Old 05-30-2003, 07:23 PM   #3
Gibbsalot
Maybe I am overlooking it, I cant seem to find the fuse.
Old 05-30-2003, 07:30 PM   #4
What year & model?
I'll look it up for you.
Old 05-30-2003, 07:31 PM   #5
Gibbsalot
1987 Shelby Lancer. Thank you so much for your help!
Old 05-30-2003, 07:50 PM   #6
I was wrong, the 1987 Lancer doesn't have a fuel pump fuse.
It looks like the pump gets voltage from the power module in the engine compartment.
Look on the power module for a 10 way (wire) connector (plug) and unplug it from the power module. With it unplugged power wont be able to get to the pump.
Old 05-30-2003, 07:56 PM   #7
Gibbsalot
k, cool, thx!
Credit Counseling | Credit Cards | Mortgage Calculator | Buy PSP | Actress
Page generated in 0.30974 seconds with 14 queries
