Old 06-02-2003, 04:14 PM   #1
Any SBEC L-bodies?
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
I finally found a '90 Omni SBEC TBI underhood wiring harness. I'm going to convert the harness for 2.5 T1 use on my Omni GLH, using a donor '90 turbo SBEC harness.
Has anybody else wired their L-body for SBEC? Does having sequential fuel injection really make the engine run any smoother? Will it make it easier to pass emissions? I guess I just want to brag about having the only sequentially fuel injected turbocharged Omni
iTurbo is offline
Old 06-05-2003, 02:50 AM   #2
No turbo SBEC L-bodies?
iTurbo is offline
Old 06-05-2003, 10:58 AM   #3
You won't be the only one for long. I am going to wire my SC for use with a SBEC from a Daytona if I can't find something better like yours. I haven't looked around that hard yet, but have a Daytona wiring harness already. It is sure to be a lot of work with the Daytona harness. The L-body configuration would be much easier.
I do have a question. They made L-body's in 1990? If so that will be the way I go since all I will have to do is add on and delete vs. redo everything. It will still be a ton of work either way. Good Luck. Pat
shelbyvnt2 is offline
Old 06-05-2003, 11:38 AM   #4
Yup 1990 was the last year for the Omni L body.
1987 was the last year for the Charger L body.
ShelbyMotorspts is offline
Old 06-05-2003, 12:04 PM   #5
My Ride: 1987 Shelby GLHS 507
Engine: 2.2 SOHC Turbo
its not sequinetal fire.
MoparBoyy is offline
Old 06-05-2003, 12:57 PM   #6
According to my wiring diagrams, '90 SBEC has four injector drivers...
iTurbo is offline
Old 06-05-2003, 04:05 PM   #7
it may but i'm pretty sure it still gang fires them.
Old 06-05-2003, 04:50 PM   #8
My Ride: Reliant
Engine: SOHC 2.5 8V
90 Omni was TBI.
gdonovan is offline
Old 06-05-2003, 04:58 PM   #9
that too
there was no Mutli port fuel injected N/A 2.2 or 2.5...
unless you got a shadow like i picked up, was a turbo car, the guy put a TBI manifold on it and never put the turbo on it. so it had a MPI and no turbo, and the car ran fine! i promply crushed it, i only wanted the seats and the car was all rotted out.
Old 06-05-2003, 06:07 PM   #10
If you guys read above, you would have noticed that I'm converting the '90 Omni TBI SBEC harness to turbo MPFI SBEC harness. The TBI SBEC has one driver, the turbo SBEC has four.
iTurbo is offline
Old 06-05-2003, 10:47 PM   #11
My Ride: Reliant
Engine: SOHC 2.5 8V
That is correct!
You know what you get when you install a turbo cal on a TBI board? A car that fires on one cylinder! lol.
gdonovan is offline
Old 06-06-2003, 12:06 AM   #12
DaytonaVNT
i found this out from experience... the SBEC that i picked up at the yard only fied one cylinder... i looked at a noid light(friends) and only 1/4 was blinking, or seemed quite steady to be precise
Old 06-06-2003, 12:35 AM   #13
Well I think it goes without saying that I'd use a 2.5 T1 SBEC with the converted harness!
My plan is to cut out the connectors and wiring (overlays) related to MPFI/turbo and integrate them into the TBI SBEC harness. The fuel rail connector and other sensors will be grafted in. I'll hopefully end up with a harness similar to the Super 60 harness, but it will be SBEC, sequential fuel injected, and have a 4-wire O2 sensor.
iTurbo is offline
Old 08-02-2003, 11:33 PM   #14
you found a 90 turbo with the harness intact? I have been looking for months and havent found one intact. pictures would be apreciated
Torka is offline
Old 03-29-2004, 10:47 AM   #15
It has been 8 months has anyone else done the swap? I bought a SBEC tbi omni harness from Todd Mefferd and plan to do this sometime in the future. If someone is looking for a good harness I think Russ Jerome might have one. I was going to buy his but couldn't wait, or so I thought.
Pat
Ringtones | Xecuter 3 Mod Chip | Guitar Lessons | Loans | eHarmony
Page generated in 0.45237 seconds with 13 queries
