Old 06-12-2003, 02:18 AM   #1
a/f gauge reading...
not sure which forum to put in but..... i am having a hard time figuring out where exactly my a/f gauge should be reading.. i have read dodgegarage, and heard different thing from different people... i have the cyberdyne gauge and it has 10 lights.. thedodge gargage says i should read 9 lights at WOT, but other people have told me that as long it is in the yellows (7-8 bars) i am fine.. what should it be reading at WOT? i have a rising rate regulator and would like to get it set so that i dont turn my engine into a paperweight..
87shelbycsx is offline
Old 06-12-2003, 02:33 AM   #2
My Ride: 1985 Shelby Charger
Engine: 2.2 T2
Get a digital volt meter & tap it in to your A/F gauge or the O2 sensor wire. Then go to your favourite test area & see what voltage it sits at under WOT. Safe would be .90-.92, although, I've seen cars running .87/.88 with out any detonation. And of course, note what your A/F gauge is reading at what voltage.
crazy1eye is offline
Old 06-12-2003, 11:32 AM   #3
I also have that same Gauge, I like running mine at the 2nd red light at the top
Chris
mastwolf is offline
Old 06-12-2003, 12:36 PM   #4
Re: a/f gauge reading...
My Ride: 1987 Shelby GLHS 189
Anyone that tells you that (7-8bars) should not be listened to...
glhsken is offline
Old 06-12-2003, 01:00 PM   #5
My Ride: 1987 Shelby GLHS 507
Engine: 2.2 SOHC Turbo
the LED a/f gauges are NOT accurate at all. I would use a volt meter.
I had two of those to test and between the 2 of them they were off as much as .15 of a volt. YUCK!!!!
MoparBoyy is offline
Old 06-12-2003, 01:22 PM   #6
This is how mine is set-up... standard cyberdyne 10 light recalibrated ACCURATELY
1 0.72
2 0.76
3 0.8
4 0.84
5 0.88
6 0.92
7 0.96
8 1
9 1.04
10 1.08
It's set-up so the second green (#6) is .92 and I'm good to go... I let out when I hit .88. Much more useful set-up this way.
glhsken is offline
Old 06-12-2003, 02:15 PM   #7
hey ken - who recaled it for you? did you do it?
rpeatt is offline
Old 06-12-2003, 02:31 PM   #8
No, A friend of mine did it... electronics and I do not get along
glhsken is offline
Buy Anything On eBay | Mortgage | Remortgages | Debt Help | Credit Cards
Page generated in 0.33584 seconds with 13 queries
