06-16-2003, 11:10 PM
My Ride: 1985 Shelby Charger
Engine: 2.2 T2
I was just doing some "testing" with gaboon(Joey), he has the same setup + a large FMIC, 44pph 5th injector, etc... The base psi with the vacuum connected was at 46, using a digital volt meter tapped into the O2, it was reading .88 at WOT with 15/16psi. When he increased the boost to 19/20psi, we heard that nasty noise called detonation, not to mention the O2 readings dropped to .84  . With this setup, the boost was getting up to 10psi or so at 4000rpm, then hitting full boost by 4500rpm, kinda slow. Tomorrow, will try my 550cc(52pph) injector in stead of the 44pph, we don't want to increase the base fuel psi to much. This is where a custom cal would help, with a custom cal you could lean out the fuel & increase the timing to help with turbo spool, then remove the timing & add the fuel as the boost rises.
06-17-2003, 12:28 AM
My Ride: 1987 Shelby GLHS 189
WAY TOO LOW!!!
I maxed +20's out at 55 base and 18 psi with a stock turbo/Ic.
Ask GLHS222.... his base was there... I think he lost a piston or 2 (he has a 46 trim as well.)
06-17-2003, 10:19 AM
Re: +20's
Originally posted by GLHS99
I didn't actually run the car at that setting. I thought this turbo needed a little less fuel to spool up. In addition I thought to get the bigger injectors to idle you had to turn down the base pressure. For example if running 45 psi the +20's flow like 38pph compared to stock TII injectors at 55 psi flowing 33pph?
Get used to the hybrid.. It's slower to spool until 4k with a 2.2. It doesn't mean it does not put "usable" power down as opposed to the stock turbo which hits so hard, the tires liqueify. Quite the opposite.. You will run quicker with it. 10 psi on a hybrid is equal to 14 on a stocker.
Yes, the idea is to lower the fuel pressure for idle. But if the injectors can't handle it up top, you'll have ashtrays. The stock LM will not like +20's @55 psi static (unplugged). The Stage II will handle them just fine. I ran like that for over a year.
The most boost you'll be able to handle with the +20's and Hybrid turbo is 16-18 psi. Even at 55 psi static. I've run just about every injector combo and fuel pressure short of 5th injectors and a rising rate. I wouldn't run a hybrid with +20's personally. If you do, a little rich down low is good insurance. ( I maxxed them out at around 270 hp to the wheels)
The only way you'll have "perfect" fuel for idle is to turn the base pressure below where they will handle the boost you seem to want. Best alternative is +40's and a custom cal or RRG reg (tough and touchy to tune)
06-19-2003, 10:29 AM
Set the base to 55 for now. The stage II cal can handle it no sweat at idle with an good flowing exhaust (I ran like that for over a year). With the hybrid, that will give you fuel for 16-18 psi. Set the 5th to come on at 14-15 psi for safety
Too many people are giving bad fuel advice on this board. The base pressures people are setting their injectors at is ridiculous. And they all want to argue until they lose a piston.
Gus had his +40's set at 18-20 psi base... no effect on the spray pattern car idled and passed emissions this way. He also had the RRg reg for higher boost. I had my +40's set at 28 base, There was enough fuel with the hybrid turbo for 17 psi of boost.
06-19-2003, 01:36 PM
#13
31 base with +20's will affect the car because of 2 little fuel at idle... literally starve it.
I've never run into a spray pattern issue. This was debated long ago on the FMML.
Stock LM's will not handle 55 psi base The GLHS MP (stage II) will. Not sure about the Daytona/shadow unit.
Ideal egt is 13-1500 for cruising.. 15-1550 max wot and 850-1000 idle.
I wouldn't go over the boost you have set with only 40 psi base pressure.. not a lot of room there.
