Old 06-19-2003, 11:49 PM   #1
Any of you know where These go?
My Ride: 1988 Shelby Z
Engine: 4Banger Turbo 2.2L
1/4: 15.500
take a look at the pic, they were cut clean off, i sure as hell didnt do it. Anyone know what they hook up to?
thanks!
ToiboTonaZee is offline
Old 06-19-2003, 11:56 PM   #2
My Ride: 1985 Shelby Charger
Engine: 2.2 T2
O2 sensor?
crazy1eye is offline
Old 06-19-2003, 11:57 PM   #3
1/4: 15.500
Ohhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh maybe! i forgot about that little 75 dollar POS. :banghead Its in a box somwhere....
Thanks!
Old 06-20-2003, 02:29 AM   #4
1/4: 13.650
Hey, someone stole my vacuum block idea!! LOL just kidding...
maybe the map sensor, and the other looks like the cal emissions solenoid plug...
joe
firebaron90 is offline
Old 06-20-2003, 03:21 PM   #5
1/4: 15.500
I went and got a plug from a car at the wreckers. I dont think its the same colors tho
Now does anyone know what to do here?
Old 06-20-2003, 03:22 PM   #6
1/4: 15.500
O2 plug - white/white/black
wire plug - orangeblack/orangewhite/black
harness wires - black black green
Old 06-20-2003, 04:09 PM   #7
Pretty sure it's green (harness signal) to black (sensor signal) on O2 sensor.
The other two just go to the heater, and it doesn't matter which one connects to what wire.
lametec is offline
Old 06-20-2003, 10:31 PM   #8
My Ride: 91 Spirit R/T
Engine: TIII
Per is right. On a three wire O2 sensor the odd color is the sensor lead, the other two are for the heating element.
86Shelby is offline
Old 06-20-2003, 10:58 PM   #9
Thumbs up
1/4: 15.500
thanks guys
Old 06-21-2003, 12:22 AM   #10
1/4: 15.500
Hey how about the big round pipe coming out of the one peice intake? is that just ANOTHER source of vacuum?
Old 06-21-2003, 01:20 AM   #11
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
Depending on what side of the intake manifold you're talking about, it's either the PCV or brake booster vacuum sources.
iTurbo is offline
Old 06-21-2003, 01:44 AM   #12
1/4: 15.500
well its an 88 TII one peice manifold, so im guessing its the brake booster source.
Old 06-23-2003, 04:12 PM   #13
1/4: 15.500
Hey the motor is up and running! two more things
On the bunch of wires that lead down to the starter, theres a thick brown wire cut clean off, as well as a 2 pronged female plug, any ideas?
Theres a ground already so the brown wire must be something else...
Old 07-03-2003, 03:52 PM   #14
1/4: 15.500
green with black - white (13 volts)
dark grey - white (barely anything)
black with green - black (fluctuating 0-1v)
The AF guage shows stoich but it does not bounce back and forth, its in the center flickering very quickly. Shouldnt the AF guage bounce back and forth?
When i had the O2 hooked up WRONG it ran much better.
Also the last time we timed it the O2 wouldnt have been hooked up right. Would this cause the idle to become so sh!tty it stalls?
Old 07-04-2003, 09:54 PM   #15
mitsudodge
Silly question, but you did let the engine warm up long enough to get out of loop, didn't ya? The a/f will just flicker in the middle until then.
Cheap Loan | Shopping | Bad Credit Loan | Per Insurance | Secured Loans
Page generated in 0.58290 seconds with 14 queries
