Old 06-22-2003, 02:52 PM   #1
LED Bulbs
Ok, please forgive me if i seem a little ricer-ish by wanting these, but i was wanting to get those LED replacement "bulbs" for 1157s.
Here's a couple examples:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2419858443
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2420165438
Ok, now some of them say that you'll need a voltage regulator type thing for the directionals, because the LEDs use less current. Im guessing a resistor inline would work just as well? Can anyone tell me how to find what value resistor i'd need?
Secondly.. people are selling clear (white), red, and amber. For brake lights.. since I still have the red lens, do you think the white ones would work better, or go with red?
Last.. has anyone used these? Are they not worth the crap? lol
Thanks
FearThe4Doors is offline
Old 06-22-2003, 03:09 PM   #2
there is ones that already have the voltage regulator build in i seen them at wallmart. but if you want you can use ohms law to find the correct value for the resistor.
V=voltage
R=resistance
I=current
R=V/I
I=V/R
V=IR
for the back i would use the white LED's they are brighter and you already have red lanses.
artur_p is offline
Old 06-22-2003, 03:30 PM   #3
cool, thanks.
i was also thinking.. couldnt I measure the resistance in a standard bulb.. then measure in the LED one... then find the difference?
Old 06-22-2003, 03:50 PM   #4
light emitting diodes work completely different from light bulbs. LED's dont have a filament inside that will burn out, they are illuminated by the movement of electrons in a semiconductor material. they have very little resistance and work with small amounts of current. thats why they require other circuits to step down the voltage and reduce current. there is a benefit to led's they dont ged hot like light bulbs and they will last anywhere between 10 and 15 years before burning out.
artur_p is offline
Old 06-22-2003, 03:54 PM   #5
i think the ones that are being sold on ebay are ready to go just plug them in.
artur_p is offline
Old 06-22-2003, 04:23 PM   #6
Thanks for all your help!
any idea how much the walmart ones are? Do they have white or just red?
Old 06-22-2003, 04:54 PM   #7
tip: if they say Chevy only, even if they look exactly the same, don't use them. I made this mistake and now have 4 led bulbs that I have no use for. All they are good for is to blow fuses.
93daytona is offline
Old 06-24-2003, 02:23 AM   #8
Why would that be?
Kinda like the magic of Honda Power Steering Fluid?
Thanks for the tip!
Old 06-30-2003, 10:48 AM   #9
My Ride: 1986 Plymouth Horizo
Engine: 2.2 Turbo
Also be wary that your new LED bulb replacements may not light up your entire light housing. My buddy put them on his neon and from the back it only illuminated a small circle in the center of the tail light that was the size of the cluster of LED's.
contraption22 is offline
Myspace Proxy | Auto Loans | Bad Credit Loan | Loans | Credit Cards
Page generated in 0.35472 seconds with 13 queries
