06-29-2003, 04:41 AM
Leaning out at top end.
My Ride: 1987 LeBaron
Engine: 2.2L Turbo II
Hey all this is actually a problem that has been happneing for a while, but i think i finally narrowed down the cause. When i take my car for a long run ie: high speed's it started to hesitate and lose some power and an audible popping noise was occasionally heard. couldnt figure it out until i started to notice that my a/f reading was dropping a bar as i starting getting up in the speed. boost stayed steady at 13psi but i started leaning out. it only does it at high speeds not high rpm. 1st and 2nd gear is fine(auto tranny)
What im wondering is what could be the cause of this leaning out at a lower then cutout boost level. should i looke into a afpr or larger injectors as the stock T2 ones ive installed dont seem to be cutting it, or could it be fuel pump related? Im still not absolutely sure this is the problem, but you can feel the drop in power as the car starts to run leaner. its a big pain, so any help would be great. thanks all.
