Old 06-29-2003, 11:09 AM   #1
anyone running fwdperformance 1988/1989 Stage 4 Calibration
spark
Does the computer control the boost to 16 pounds? or do I need a boost controller to get 16??
If so how do u like it??
Any pro's or con's??
I'm also going to get the +40% injectors, 3bar map sensor when I order it. larger exhaust will come later down the road.
Anything else I will need??
thanks
Old 06-29-2003, 02:48 PM   #2
Dont mean to hijack your thread, but do those calibrations revise your shift points on an a/t? if so, I'll probably get one. I'm sure those calibrations actually control the boost, it's just a matter of working the solenoid AFAIK.
kmcdon3960 is offline
Old 06-29-2003, 09:57 PM   #3
My Ride: 1989 Shelby CSX
Engine: 2.2 16v Hybrid
if the computer is calibrated to give you 16lbs then just hooking the wastegate up to the selinoid correctly will give you 16lbs...you'll need a manual boost controller to go higher or lower
The computer doesn't control the fift points on the autos...so they would be the same
scott is offline
Loans | Debt Consolidation | Mobile Phones | Credit Cards | Myspace Proxy
Page generated in 0.30905 seconds with 13 queries
