Old 07-01-2003, 08:41 PM   #1
Digital Dash Q.
My Ride: 1987 Shelby Charger
Engine: 2.2L Turbo I
You know the digital dashes that came with certain 84-87 Lebaron/Lancers, is there some way to change the Millage to whatever you want? One more question, how accurate is the Tachometer on those digital dashs? I heard stock ones arent, but I was thinking sense its digital, it might be diffrent.
Cliff Notes:
1 ) Change millage on digital dash?
2 ) How accurate is the digital tach, better go with a aftermarket?
ShelbySean is offline
Old 07-01-2003, 10:54 PM   #2
My Ride: 1987 Daytona Shelby
Engine: 2.5 16v
the tach is accurate just slow too respond on the older models
Garret is offline
Old 07-01-2003, 10:55 PM   #3
1: Why would you want to do that? Isn't that fraud? (possibly a battery inside the dash itself, if it's a non-volitale memory chip, prolly not to be messed with)
2: I'm sure its accurate to a degree, but certianly not as accurate as a well built, properly installed (read: PROPERLY) aftermarket tach.
kmcdon3960 is offline
Old 07-02-2003, 01:04 AM   #4
I wanted to know so I can change it to match my existing mileage on another car.
So they are slow huh, is there anyway to speed it up?
Old 07-04-2003, 04:56 PM   #5
Not sure on the mileage thing, but the tach's are semi accurate. The problem is it can only measure in 250rpm measurements, that's why it seems slow. I use an aftermarket tach because my digi one goes dark at times.
LaserB is offline
Repair Bad Credit | Xecuter 3 Mod Chip | Watch Anime Online | Debt Consolidation | Ringtones
Page generated in 0.31636 seconds with 13 queries
