07-05-2003, 10:30 PM
Fuel injectors are rev limiting me! Dirty?
My Ride: '89 2.5 Turbo Spirit
Engine: 2.5 Turbo
I'm having problems with my 87 Daytona T1 converted to 89 blow through with no intercooler.
First of all, the power sucks. It might as well be a TBI motor, because it sure doesn't act like a turbo should!
After running the car about 20 miles today, I had a problem where it wouldn't rev any higher than about 3000 rpm. I could put my foot way down on the gas, and the tach would just bounce from 2000 to 3000 about every 2 seconds.
So since it had 5 gallons of gas in it, my Dad had the idea to add 2 cans of PB Blaster solvent to the fuel tank. So we did. Then I set the idle at 1500, put a fan in front of the car, shifted it into Neutral, and went inside to watch the NASCAR race for an hour while it ran the fuel through. It sucked down a few gallons.
I took it out for a drive afterwards. It still won't idle, and I didn't really try to test the upper rpm limit.
Before the 1 hour run, I'd checked the spark plugs, and all were rich, especially #1 and 2. I have 2.5 injectors on 1 and 2, and 2.2 injectors on 3 and 4, as was sugested here.
Fault codes are 12,13,15,24,34. 24 is the TPS sensor. It wasn't like that earlier today.
If this thing doesn't get fixed soon, this POS is getting sold! My old 1970's Mopars with carburetors never gave me any of this trouble!
Should have bought that 5 speed TBI 89 Omni when I had the chance.
