Old 07-30-2003, 06:39 AM   #1
No left turn signal.
getragguy
On my 88 Shelby Z, there is no left turn signal. Front or rear. when I turn the left signal on, the lights turn brighter, but do not flash. I have checked the front two bulbs to see if one filiment is burned out, but neither are. And in adition to that, the left arrow is half way on the whole time, and just gets twice is bright when turned on. I would really appreciate any help that could be offered.
Old 07-30-2003, 07:41 AM   #2
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
Check for bad grounds. Especially check the two on both side inner fenders, behind the headlights. Could also be a faulty flasher.
iTurbo is offline
Old 07-30-2003, 07:47 AM   #3
My Ride: 87 Shelby CSX #400
Engine: 2.2 turbo 2
I've seen this happen with blown bulbs.
IIRC when your blinker wont blink it's the rear that is out. And when the "arrow" on the cluster is on at half brightness all the time it is the front that is blown. Or it could be a combination of small push in corner marker bulbs blown.
Also if you look at rear tail light sockes the grounds in the socket break and you have to use the famouse "sheet rock screw" fix. (carfuly screw a sheet rock screw into the back of the socket where the ground wire goes in. this makes a conection between the ground ring of the socket and the crimp on the end of the ground wire.
HYDCSX400 is offline
Old 07-30-2003, 08:01 AM   #4
getragguy
I'll check the two front bulbs again. I've got new ones, so I guess its time for trial and error. Hopefully I don't have to ghetto rig the rear on up. Oh well if I do.
Old 07-30-2003, 08:08 AM   #5
Engine: 2.2 turbo 2
I fought the whole sheet rock screw mod too, sounded too getho for my CSX. This spring i had to give in and just do it.
Credit Cards | Guitar Lessons | Xbox Mod Chips | Mortgage Calculator | Remortgages
Page generated in 0.30104 seconds with 13 queries
