Old 11-22-2006, 05:41 AM   #16
My Ride: 88' Shadow ES
Engine: 2.2L DOHC Hybrid
Originally Posted by bfarroo
So is there a source for the pin needed to install the wire in hole 21?
Benji
Best place I've found to get pins for in the 60-Way connector at the SMEC is from the junk yard. I found an 89 TBI Daytona that was about to be crushed and just cut the whole 60-Way connector off the wiring harness leaving about a foot of wire. All the pins I'll ever need.
As for the original question about pin-21. My '88 T1 Shadow had no wire, and no hole for pin-21. I had to pull the 60-Way connector apart and drill out the plastic for pin-21 when I wired up my IAT sensor.
Shadow92_22 is offline
Old 11-22-2006, 10:46 AM   #17
look here
My Ride: 89 voyager le
Engine: 2.5 L t1
look at this link complements of xrattiracer.
http://www.merkurboys.com/wiki/index...xtraPinInstall
he explains and shows how to do it very clearly.
WowZer is offline
Old 11-23-2006, 03:12 PM   #18
My Ride: 89 LeBaron & 99 WS-6
Engine: 2.5L turbo & 5.7 LS1
this should really go for the faq
LynX853 is offline
Myspace Codes | Myspace Layouts | Share Prices | The eBay Song | Mortgages
Page generated in 0.34905 seconds with 14 queries
