12-25-2012, 11:43 AM
#25
Re: 1992 Custom Ecu LOOK!
My Ride: spirit rt/IROC rt
Engine: vnt 2.2l/2.2t3
[QUOTE=Shellgame;2257641]The 4 pins to the right lower corner of the SBEC are the re-flash control pins. If you swap in an 87C257, you don't use those pins.
QUOTE]
The way I'm looking at the board, these comments seem to contradict each other, don't they? Which one is correct?
I'm looking to socket my '92 rt sbec in the next day or so and came across this after being confused about the mis-matching number of pins...
When looking at the "top" of the board (the side that the harness plug plugs into), there are two heat sinks under the main plug, then the chip is to the lower right of that in the corner. When re-socketing this thing, do you ignore the 4 pins closest to the heat sinks (seemingly what una said), or the 4 pins closest to the corner of the board (shellgames suggestion)?
