Old 10-14-2003, 11:48 PM   #1
2.5 turbo 2 questions
baron4406
Just bought an '88 Shelby Daytona that has a 2.5 swapped into it. The previous owner was running the 2.5 SMEC, however I got the original turbo 2 SMEC with the car. Naturally I'm gonna run the T2 SMEC. Also the car has the Garret T2 turbo NOT the 2.5 Mitsu turbo in it. I've got some work to do to the car, mainly fix the engine and rebuild the turbo- I'm just wondering if that T2 computer will supply enough fuel for the bigger 2.5. I'll run a multimeter on the O2 to seem what happens, any guesses??
Old 10-15-2003, 09:40 AM   #2
Here's my guess. In a few weeks you will ask what the best replacement pistons are.
It will run lean.
MachineHead is offline
Old 10-15-2003, 12:45 PM   #3
you can put +20 injectors in with the 2.2 computer to make up the extra fuel, and you can back the timing off to 8* or so to relax the spark curve a bit. it will run tolerably well after that, but if the option is yours and you don't really have to, i'd put the 2.5 computer on it with a manual boost controller. you're engine will be happier.
tony
macncheese is offline
Shares | Property for sale in Spain | Free Credit Report | Credit Cards | Debt Help
Page generated in 0.34770 seconds with 13 queries
