Old 10-24-2003, 03:21 PM   #1
8 lIGHTS AT LOW BOOST
oK CURRENTLY IM ONLY RUNNING AROUND 10-13 PSI... NO MATTER WHAT I ONLYG ET 8 LIGHTS ON MY AIRFUEL ( CYBERDYNE) ONCE IN AWHILE ILL GET 9 BUT 8 IS OPRETTY MUCH ALL I GET AT WOT IN 3RD 4TH AND 5TH.. COULD IT BE TEH FUEL FILTER OR SOMETHING ELS.E. WOULD ADDING A 5TH OR 6TH INJECTOR HELP IM GONNA TRY ADDING THEM THIS WEEKEND.. THANX
frostburner is offline
Old 10-24-2003, 03:42 PM   #2
wich year O2 are u running? did you ground your gauge well? Usually 1wire o2 seem to read a tad lower.
Danny
P.S loose the caps :big grin:
Turbolag87 is offline
Old 10-24-2003, 05:03 PM   #3
IM USING THE 89 4 WIRE O2 SENSOR, ILL SEE IF I CAN REGROUND IT OR I CAN PUT IN ANOTHER O2 SENSOR FROM MY OTHER CAR WHICH IS ALSO A 4WIRE..
OH SORRY ABOUT CAPS BUT IM AT WORK AND ALL THE NOTES AND EVERYTHING I HAVE TO DO FOR MY MECHANICAL DRAWINGS HAVE TO BE IN CAPITALS SO IM TOO LAZY TO TURN THEM OFF.. ANYONE ELSE HAVE ANY OTEHR IDEAS.. AM I STILL SAFE AT 8 LIGHTS.. THANX LET EM KNOW
Old 10-24-2003, 05:25 PM   #4
i wouldn't stay at wot with only 8 lights. for sure change the fuel filter if you haven't recently, inspect all fuel lines for anything not right, i've seen a couple pics of crimped/bent metal lines or possibly some old fuel line has gotten weak and collapsed?? i'm not sure if that happens but you never know. you should also check the fuel pressure, the pump could be getting weak and your not getting all the fuel you need.
89daytonaTII is offline
Old 10-24-2003, 10:43 PM   #5
thanx i change dteh fuel filter todya and the gas taht came out wasnt clear it as almost black .. so im guessing it wa sno good.. lol.. havent driven it yet but ill see how much it helps out and i have a 255 walbro pump waitign to get installe dbut i ahvent had teh chance.. should taht help some also..
Home Loan | Bleach 149 . Bleach 150 | Car Loans | Share Prices | Loans
Page generated in 0.29860 seconds with 13 queries
