Old 11-04-2003, 10:26 PM   #1
Stock FPR's ?
MadDog70
My 89 Shelby isnt running right. It idles ok. On the road it runs good if you are just breathing on it 1/4 throttle. but as soon as you try to pick it up a little it looses all power. I just put in a new fuel pump and filter. Thought it was a plugged cat, but now I am not sure. Vaccum looks ok and I dont show any codes. I am leaning toward the FPR now. Are the stock FPRs known to go bad? Please give me some ideas.
Old 11-04-2003, 10:51 PM   #2
cawcislo's Avatar
My Ride: 87 Shelby daytona T2
Engine: 2.5 bored 0.20
Feedback: (6)
Images: 4
Sometimes they do go bad. Is the vacuum line going into it okay. You'd have to hook up a fuel pressure tester and do some more tests.
cawcislo is offline
Old 11-05-2003, 11:13 AM   #3
MadDog70
If the problem is sensor related or ignition wouldnt it show a code. could it be injectors? It is almost like it looses fuel.
Old 11-05-2003, 07:18 PM   #4
they do go bad i just swaped out mine because it rupersured and i had fuel in my van lines well in my baro line
csxt#10 is offline
Ringtones | Car Loans | Credit Cards | Property in Spain | Equity Release
Page generated in 0.28068 seconds with 13 queries
