Old 12-07-2003, 12:53 AM   #16
turbo600
turboxt never said he had any problems other than his gauge was reading differently after he converted to t2. your sensor obviously was the problem because it stopped moving altogether. even if you got a new bosch at that point it would have fixed your problem. basicly what i was telling him was that whatever the gauge is doing now will be normal and not to worry because the sensor is still ok. plus, whenever you change something that affects airflow into the engine, the computer has to readjust it's short term and long term fuel trim, which takes a while, so his readings might get closer to what he used to see.
Old 12-07-2003, 01:01 AM   #17
My Ride: 89 Daytona ES
Engine: 2.2L TII
sorry! didn't mean totally frozen it would move but not like it's supposed to. oh yeah that was a brand new bosh with maybe 50 miles on it.
it's not normal. to see the guage slugishly move back and forth. while driving at a constant speed it should bang back and for so rapidly you won't be able to get a decent reading. then at WOT the computer ignores the sensor and goes off a preset calibration therefore the gauge show a steady reading.
diabloed is offline
Old 12-07-2003, 01:07 AM   #18
turbo600
that's enough to piss a guy off. if i was in your spot i wouldn't buy another one either.
Old 12-07-2003, 01:12 AM   #19
Engine: 2.2L TII
well honestly it being bad would probably be my fault (not sure though)
when i did my TII swap i was unaware of having to change the fuel pump. so i was running WAY LEAN. 14.5psi fuel presure vs. 55psi. i know that didn't help matters much, but with only 30-50 miles of testing it shouldn't have gone bad i would think.
diabloed is offline
Old 12-07-2003, 01:26 AM   #20
My Ride: '89 CSX T3/T4
Engine: 153ci
how hard is it to install an o2 sensor on a 1 pc intake????
TurboXT is offline
Old 12-07-2003, 01:29 AM   #21
Engine: 153ci
i know for a fact that they are better. i just went through a whole ordeal a week ago.
car would chug until fully warmed.
if i stopped anywhere it would chug for a couple of blocks.
idles fluctuated between 500-1000.
A/F guage totally frozen.
overall poor performance.
bought and installed the new NTK sensor. EVERYTHING is all better.
I'm not saying that all his problems are going to go away, but getting the new (proper) sensor will put that fact to history. that will 90% garuntee fix his A/F gauge problem. this is if the rest of the car is in working order.
define "chug"
that might be what my car is also doing, if i dont let my car warm up for awhile at a cold start up. it will kinda buck and hesitate a lil bit until its warm.
TurboXT is offline
Old 12-07-2003, 01:39 AM   #22
Engine: 2.2L TII
BINGO!
diabloed is offline
Old 12-07-2003, 01:49 AM   #23
Engine: 153ci
ok. did ur car not idle right too? was it hard to start when cold.... well not hard but it took longer then normal...
TurboXT is offline
Old 12-07-2003, 01:53 AM   #24
Engine: 2.2L TII
yuppers same thing as mine. mine would run "ok" when it was fully warmed up and if i stopped to get gas it would chug again for a couple blocks than be "ok" again. idle would lope too.
diabloed is offline
Old 12-07-2003, 12:00 PM   #25
turbo600
the o2 sensor goes in the exhaust right after the turbo, just unscrew and unplug the old one and screw in and plug in the new one.
Old 12-07-2003, 01:02 PM   #26
Engine: 153ci
well i've changed one when i had the log manifold, but it seems like this manifold would just be in the way
TurboXT is offline
Old 12-07-2003, 01:26 PM   #27
Engine: 2.2L TII
it's definately a one handed job with a 7/8 wrench. it's just way down there right by the turbo.
diabloed is offline
Loans | Credit Card Debt Consolidation | Teen Chat | Mortgages | Ringtones
Page generated in 0.83073 seconds with 13 queries
