Old 12-09-2003, 02:54 PM   #1
Lack of ignition???
TheGC
Ok... Here's the deal. On a recently acquired car, I replaced cap, rotor, plugs, wires, and coil. I am still burning RICH on idle and low end (stoich says so and you can smell it). The engine starts stumbling on soft acceleration @ 1500 rpm. It keeps stumbling until boost kicks in. Any suggestions?? Is my distributor going bad?
'84 laser with '89 daytona 2.5
Mitsu turbo w/ 10 lbs-22lbs of boost (controller inside car)
intercooled w/ 5th injector (unplugged at moment to diagnose problem)
Heads freshly rebuilt
I don't know much else about it yet.
thanx
Old 12-09-2003, 02:56 PM   #2
My Ride: 1987 Shelby GLHS 189
Have you checked codes??
glhsken is offline
Old 12-09-2003, 02:58 PM   #3
Ummmm, no
TheGC
That's a thought, but i don't know how. Do i need a code reader?
Old 12-09-2003, 03:06 PM   #4
turn the ignition on-off-on-off-on-off and the c heck engine light will blink. Do a search and you should be able to find a list of what the codes are (or just tell us and we can find out)
kmcdon3960 is offline
Old 12-09-2003, 03:47 PM   #5
thanx
TheGC
ill try that now and post back the results.
Old 12-09-2003, 03:56 PM   #6
Got 'em
TheGC
Ok... I got a code 35 (fan)
doesn't matter... i'm running an always on electric anyway
and a code 51 (lean)
??? I'm running rich as hell... need new O2 sensors??
then code 55 (end of message)
Any thoughts?
Old 12-09-2003, 03:59 PM   #7
Code 51 indicates the 02 sensor is not working correct.. To protect the engine, the car's limp in mode is to set it rich...
Install a new 02
glhsken is offline
Old 12-09-2003, 04:04 PM   #8
****... i was hopin that the comp was wrong
TheGC
I'm cheap... dammit. the car was free!!! lol. The sensor is like $45 at autozone and i almost bought one earlier without knowing the actual cause. OK cool, thanx for the help diagnosing it... i'm headed down there now
Page generated in 0.14598 seconds with 8 queries
