12-22-2003, 01:12 PM
Fuel pressure for +20 too low?
Engine: 2.2 VNT
90' Daytona here are my mods:
AFPR, Forward Motion Enforcer 2 turbo, Forward Motion stage 2 cam, ported intake/exhaust manifolds, big valve head, 52mm throttle body, 3" exhaust, +20 injectors
My A/F guage started reading lean at boost and I tracked it down to the fuel pump going, replaced the fuel pump with a Walbro 255 (same model as old one).
It is not as lean under boost as before but I still get a lean reading on A/F guage anything over about 13 PSI. I used to have a rich reading before with more boost.
I checked my fuel pressure and I get 30 PSI at idle (37 w/ vac line disconnected).
Is my base settings for the Fuel Pressure too low? My guage jumps around at idle and at speed so I figure it should not be the O2 sensor (no codes), but I could be wrong.
