12-24-2003, 02:56 PM
you can simply unplug all of the solenoids. some will throw codes, but dont affect operation at all. the speed sensor can go away, but be prepared to do lots of heel-toe gas pedal management when coming to a stop. the smec harnesses i make for use in ford vehicles has only charge temp and engine coolant temp sensors (along with the obvious tb, dist, map, etc) and speed sensor for daily drivers. probably remove at least 100ft of wire from a typical harness
