11-22-2012, 08:57 AM
Re: Lean condition
Super Pope
BTW, other than "problems" the MP Shelby stage 2 runs really lean for power. You just made a big change in flow. I did 3" exhaust and mild porting and the car required +20s or FFVs just to not detonate. Of course a new fuel filter and maybe a new fuel pump. Then getting the injectors cleaned by mister injector is good too. Also the fueling is for a 32 lb GLHS injector not a 34.5 lb T2 / 2.5 injector. So those are an upgrade to a little more fuel. The stage 2 also doesn't like bad fuel, Chevron 92 is a must or Sunco 100.
Also my car always had a real problem with timing and sputtered. I ran my timing to 14 instead of 12 with the water temp pulled and the car was very happy. I also didn't add dielectric grease to the connectors when adding the new computer and the thing sputtered and would die when GLHNSLHT2 here would hit the computer with his foot lol.
I love the stage 2 for what it is, but it has no tolerance for any problems. The stage 2 will melt pistons or just not let the car run sometimes. So you can't have any issues. That means every sensor cleaned and greased and working right. Clean injectors and a new filter and pump. The right timing or a hair more and 92 fuel. Any one of those 3 out of place and your asking for damage, but all 3 in place and woohoo fast though with low boost lol.
Rob Walsh
84 DC Shelby Rampage
86 GLHS 76
89 CSX 187
05 PT GT
93 Cummins
