AF gauge on Na car - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo Dodge Technical Chat > Engine Management, Fuel, Spark, EGTs, and Air/Fuel Ratios
Old 12-31-2012, 11:29 PM   #1
AF gauge on Na car
Cloud car owner.
GhostDaytona's Avatar
My Ride: 96 Dodge Stratus
Engine: 2.4L DOHC
GhostDaytona is traveling down a dark road
Ok first, why?
Second, does it work?
Third, since its not turbo, what would readings be?
Car, is my new, 74,000 mile 2.4L DOHC Stratocloud car, lol
GhostDaytona is offline
Old 01-01-2013, 04:43 PM   #2
Re: AF gauge on Na car
My Ride: 1992 Spirit ES
Engine: 2.2L T2
Images: 40
Tranquillity is keeping the peace
It could help to see if your O2 sensor is working well and might help to tune a bit depending on what you're doing. I don't think it's really needed on an N/A car unless you're getting pretty involved with the motor. Might make you look cool to some little teenyboppers though haha.
Tranquillity is offline
Old 01-02-2013, 01:26 PM   #3
- OFFICIAL GEARHEAD -
My Ride: Dak QC/Omni/SL/XR7
Feedback: (84)
detobias is keeping our cars running
1. same reason(s) as a turbo EFI car: verify operation, tuning
2. yes, will work just fine.
sensor doesnt know whether its on a turbo-, super-, N/A efi or carb, or diesel or NGAS or propane for that matter
3. most N/A calibrations also have 'overfuelling' in the heavy throttle / heavy load region, so you should see a drop in A/F past a certain throttle position &/or RPM
detobias is offline
Old 01-02-2013, 07:00 PM   #4
NAJ's Avatar
Feedback: (21)
My Son's 3.0L N/A reads 14.7/1(stoichiometric)at idle and no load cruise and 12/1 @ WOT with all stock components.
Old 01-02-2013, 08:39 PM   #5
Legendary Driver
GLHNSLHT2's Avatar
My Ride: 85 GLHT, 87 ShelbyZ,
GLHNSLHT2 has really helped outGLHNSLHT2 has really helped out
my 04 jeep libby is 14.1-14.3 at cruise/idle. 12.7-13.2@wot.
GLHNSLHT2 is offline
Old 01-02-2013, 08:53 PM   #6
Hybrid Booster
My Ride: 90 Daytona ES
Engine: 2.5 Turbo 1
acannell is keeping the peace
i would say a narrowband a/f gauge is a very worthy item on an older car for diagnostic reasons alone.
for instance:
-you have a fuel leak somewhere and the car runs rich, eventually destroying your o2 sensor, catalytic converter, spark plugs, and maybe even other things depending on how rich and how long (this happened to my jeep..a narrowband gauge would have alerted me to it LONG ago and saved me a couple hundred bucks in parts and smog tests)
-fuel injectors/fuel pump/fuel lines clogged/inoperative so system runs lean at WOT..this will tell you that
-if you car is known good right now, you will get used to the the readings and when something goes wrong in the future you will know right away
plus they are cheap
acannell is offline
Old 01-04-2013, 02:50 PM   #7
---SITE GUIDES---
6g72 acclaim's Avatar
My Ride: 95 acclaim, 06 strat
Engine: 6g72 and 2.7
6g72 acclaim is keeping the peace
I have a narrow on my acclaim, it recently helped me in determining what was causing it to run poorly. I agree well worth the money.
6g72 acclaim is offline
