01-15-2004, 06:12 AM
Location: a box under the stairs in the corner of the basement of the house half a block down the street from jerry's bait shop...you know the place!
yes, it will DEFINATELY affect the driveablility of the car. vac/boost signal to the wastegate is what contols the boost levels. no boost to wastegate = constant spool. it should actually feel pretty quick. on the downside, boost too high, and the stock fuel system can't handle, then you melt a piston. check my sig. upside, the car will USUALLY cut out right before 15 psi, which is where this usually happens. however, it is very violent and i don't recommend it. see if you can kidnap another vac line, maybe from the egr or something.
tony
