01-16-2004, 08:48 AM
#22
i get a pulse(flash) on the neg side of the coil when cranking (which means my brand new HEP is working correct?)
Yes, sounds like the HEP is working properly. Did you measure between the + and - terminals on the coil, or did you get + from elsewhere? Assuming you were using a testlight?
grounded the neg side of coil and it made a spark, bad ecu?
What about the + side, did you have that connected to a + source? The ASD relay will only power the + side of the coil if the engine is turning. If you didn't jump the + side and weren't cranking the engine when doing this test, there shouldn't have been a spark.
fuel pump and injectors work fine i checked them
Good.
so im thinking it hassssssss to be a bad ecu, the ecu is out of the car now and i am trying to find a computer, 187$ from napa, reman, i need to find something cheaper, any ideas of where to get one cheap?
Sounds like it might be the ECU, yes. .Junkyard or the parts wanted section here are good places to get 'em. Should be able to get one for well under $50, assuming someone has one for sale.
