vacuum line problems - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 7 Old 01-24-2013, 07:34 PM Thread Starter
My Ride: 90 Daytona 2.5 Turbo
ok guys my 90 daytona 2.5 turbo, my vacuum lines that are on it behind the valve cover were all broke. i have no idea what ones go where. i have looked at diagrams and they confuse me even more. does anyone have pics of there stock ones? or what ones can i get rid of. help plz
MoparHead340 is offline
post #2 of 7 Old 01-24-2013, 08:24 PM
Just A Guy
NAJ's Avatar
Re: vacuum line problems
Welcome To TD!!!
If the plastic vacuum harness lines broke you do not want to splice them as a "permanent" fix since splicing only creates leaks.
What you are going to want to do is install a vacuum block with new vacuum line.
The lines coming from the manifold source runs to Solenoids, (Baro, Wastegate, Canister Purge) Fuel Pressure Regulator and Boost Gauge(If Equipped).
Your other plastic lines behind the valve cover should run to the turbo and from the throttle body to the vapor canister.
Here is the link to a thread on vacuum blocks.
http://www.turbododge.com/forums/f4/...-93-turbo.html
Here are some pics of the components so you can see what they look like.
1990 2.2L VNT WITH VACUUM BLOCK(NOT ENTIRELY THE SAME AS YOUR 90 T-1 BUT YOU GET THE IDEA)
MAP SENSOR AND BARO SOLENOID
Jan
1990 Daytona Shelby VNT
37 Years ASE Certified
NAJ is online now
post #3 of 7 Old 01-24-2013, 09:44 PM Thread Starter
awesome that helped alot! i will be buying the valve for it soon. that looks alot better!
post #4 of 7 Old 01-24-2013, 10:30 PM
Das Beste Oder Nichts
92TurboTona's Avatar
My Ride: 92 Daytona
Engine: 2.5L T1
hey NAJ dumb question but is that mobil one plaque factory or did you add that as i like that plaque
92TurboTona is offline
post #5 of 7 Old 01-24-2013, 11:26 PM
Legendary Driver
GLHNSLHT2's Avatar
My Ride: 85 GLHT, 87 ShelbyZ,
or you can buy factory size nylon or upgrade to factory size polyurethane from here: Flexible Pneumatic Tubing & Hoses | AutomationDirect.com
and have a vac harness that hides in the engine bay like this: 100_1363
Instead of dominating the engine bay like a vac block does.
Here's a factory complete setup for 88+ intake manifolds using the poly line. Factory nylon would look similar as well. 100_1732
GLHNSLHT2 is offline
post #6 of 7 Old 01-25-2013, 05:59 AM
Just A Guy
NAJ's Avatar
The Mobil 1 plaque was factory from an early/mid 90's Corvette.
Back in 95/96 we had one traded in and I saw the plaque, went to our parts dept (We were Olds/Jeep/Eagle) and they ordered one.
Cost was $5.00 and it came direct from Bowling Green, KY, home of the Corvette.
NAJ is online now
post #7 of 7 Old 01-25-2013, 11:35 AM
My Ride: 92 Daytona
Engine: 2.5L T1
might have to order me one as those are pretty nice
Human Verification
