1992 2.5 turbo map sensor wiring diagram? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 24 Old 01-24-2013, 10:36 PM Thread Starter
Garrett Booster
My Ride: 93 sundance duster
Engine: 3.0 soon to be 3.0T
anyone know what wire is what? has 3 wires, obviously. lol
just wanna know which is ground, signal, and whatever the other one is
thanks!
ShadowManSRT6 is offline
post #2 of 24 Old 01-25-2013, 06:09 AM
Just A Guy
NAJ's Avatar
Re: 1992 2.5 turbo map sensor wiring diagram?
With Connector facing you and lock tab at top starting left to right.
BK/LB...Signal Return
DG/RD...Signal Line
VT/WT...5 Volt Reference
post #3 of 24 Old 01-25-2013, 04:28 PM Thread Starter
Garrett Booster
thanks man!
post #4 of 24 Old 01-26-2013, 04:51 PM Thread Starter
Garrett Booster
isn't one of the 3 wires a ground wire? or is it grounded some other way!?
post #5 of 24 Old 01-27-2013, 06:00 AM
Just A Guy
NAJ's Avatar
Signal Return is a ground internal to the engine controller.
Are you having a problem?
post #6 of 24 Old 01-27-2013, 10:50 AM Thread Starter
Garrett Booster
not having problems. just wanna hook up my fuel cut defender.
gonna use that until I can afford a new computer and a 3 bar map.
post #7 of 24 Old 01-28-2013, 07:49 AM
Just A Guy
NAJ's Avatar
So you are clamping the Map so it will not see over 14.5 lbs of boost(2 bar)?
post #8 of 24 Old 01-28-2013, 09:37 AM Thread Starter
Garrett Booster
yessir! that's my plan.
woulda had it done by now but now having a no start issue with the car.
might be a bad fuel pump but not sure.
just got it back together after doing the head gasket, fmic, BOV, etc
ran great for a few days now nothing. lol
post #9 of 24 Old 01-28-2013, 09:47 AM
Just A Guy
NAJ's Avatar
What' s missing? Fuel, Spark, Compression?
Any fault codes stored?
post #10 of 24 Old 01-28-2013, 01:31 PM Thread Starter
Garrett Booster
no fault codes. haven't gotten to get into checking the other stuff yet cuz of our crazy weather I don't hear the fuel pump turn on tho when I turn the key on
post #11 of 24 Old 01-28-2013, 03:00 PM Thread Starter
Garrett Booster
maybe the car is mad at me for molesting her. lol
I just couldn't resist! a clean low mileage car was just asking for upgrades!
post #12 of 24 Old 01-28-2013, 04:06 PM Thread Starter
Garrett Booster
post #13 of 24 Old 01-28-2013, 04:37 PM
Just A Guy
NAJ's Avatar
No fuel pump prime on initial key on = no ASD relay actuation.
Verify both power sources are present at the relay, may have blown a fuse.
post #14 of 24 Old 01-28-2013, 05:52 PM Thread Starter
Garrett Booster
I did check the fuse for the fuel pump....not blown
guess I should find a way to check the relay. maybe that's the culprit.
post #15 of 24 Old 01-29-2013, 05:03 AM
Just A Guy
NAJ's Avatar
You need to check the 2 power feeds into the relay at the relay.
Did I send you powertrain wiring?
Human Verification
