Fuel injector wiring harness - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo Dodge Technical Chat > Engine Management, Fuel, Spark, EGTs, and Air/Fuel Ratios
Old 01-27-2013, 05:40 PM   #1
My Ride: 1988 Shadow CSX-T
CSX-T 940 is keeping the peace
Hello all TDer's. I tore my car apart to do a rebuild. Now its time to put it back together and I'm not 100% certain on the sequence for the fuel injector wiring harness.
I notice each injector connector on the harness is numbered (1-4), but its impossible to install them to the matching corresponding cylinder because the wiring isnt long enough.
I need to know what number injector connector connects to what particular cylinders' injector.
Thanks in advance peeps.
CSX-T 940 is offline
Old 01-27-2013, 07:18 PM   #2
Re: Fuel injector wiring harness
TD Extreme User!
Feedback: (47)
tryingbe is keeping the peace
The wiring came off the car and it should go right back on. You can't really plug the connector into the wrong injector as there is barely long enough for each injector.
tryingbe is offline
Old 01-27-2013, 07:22 PM   #3
Thank you for the response but, I don't want to assume how it was before is correct (I bought the car on the verge of death).
Additionally, it is possible to hook it up a couple different ways with the amount of wire in the factory harness...
Old 01-28-2013, 08:19 AM   #4
NAJ's Avatar
Feedback: (21)
The injectors are fired in batches 1/2 and 3/4.
As tryingbe stated the "factory" harness injector connectors when wired correctly will only reach to the individual injector it is supposed to connect to but....
If someone repaired the harness and made the wiring longer....
I rebuilt my injector harness with all new pigtails but made the new pigtails about the same length as the factory then soldered them in.
PM being sent with wiring.
Old 01-28-2013, 10:49 AM   #5
Level 3 Supporter
4Daytonas's Avatar
My Ride: 84 Turbo Z, 91 Shelb
Engine: 2.2-2.5
Feedback: (30)
4Daytonas is keeping the peace
For general usage
4Daytonas is offline
Old 01-28-2013, 05:11 PM   #6
Harness definetely appears to be "factory".
Where does it ground exactly??
