01-31-2013, 10:57 PM
Stage 3 cal fwd performace
My Ride: chrysler lebaron
Engine: 2.2 turbo 1
I bought a stage 3 cal from fwd performace. In the discription it metions its set for 15lb of boost...Name: ECU 1988/1989 Stage 3 Calibration
Core Charge: $125.00
Part Number: FWD 75-0402
Description:
15 pounds boost, revised spark and fuel curves , modified wastegate tables for faster spool up. O2 feedback, active knock retard, increased rev limiter and over boost protection provided. Revised fan schedules for better cooling. Great for use on stock or modified turbo 2 intercooled (2.2L) cars, using stock or 804 injectors, stock map sensor, and stock or larger exhaust. Retains and enhances cruise control functions.
All our calibrations are socketed at no added expense
I thought the map sensor will only read up to 14lbs. Will I have to trick the map with a resistor, or is it something with the cal that lets it get to 15lbs? BTW Cindy at FWD performace is most helpful. I just have an odd scheduel and with the time zone change, its hard for me to call her and ask.
