03-02-2013, 12:42 PM
#35
Re: 88 Omni, Running issues, Need some advice.
My Ride: 88 Dodge Omni
Like I said- the first time I tried it, it didn't look off- the second time it kinda did- like a hair- seriously. Not trusting my judgement, and not having anyone around here physically that can help (and being I just came back from shop number 4 that wants to charge me for nothing or not even bother)- I don't know what else to do to eleminate that as a problem except to move it forward by that tooth or two and see if it runs better then. My timing cover is cracked- I'm not sure if I'm having issues using the method you posted because of that. I have a new one to put on, but I can't get it to actually go on without- I think? losening the bottom cover first, in which case, I'd already be halfway there. I suppose then, I'd have the opportunity to inspect the components some too.
on my other post, someone said you would just come to TDC, losen it up via the tensioner rotate the cam by hand, and put the belt back on, retighten. So I though I could mark the belt and cam in relation to eachother with chalk, and try that. ??
