TPS wont go lower than 1.03 volts - Page 2 - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #16 of 25 Old 02-26-2013, 09:34 AM
Just A Guy
NAJ's Avatar
Re: TPS wont go lower than 1.03 volts
FYI...
Be aware that the CTS has a duel resistor so voltage will decrease as the engine warms and then it will increase again as the second resistor kicks in.
post #17 of 25 Old 02-26-2013, 10:39 AM Thread Starter
My Ride: 07 Magnum, 84 600 tu
ok, good to know...thanks.
so, should i just probe the output, and ground on the block?
jameslleary is offline
post #18 of 25 Old 02-26-2013, 11:35 AM
- OFFICIAL GEARHEAD -
My Ride: Ram HFE/Omni/SL/XR7
yes, any "-" source will work
I'm with NAJ, yur low vacuum idle is the primary culprit for the rich running...
and the CTS is likely contributing since I'm guessing the ECM will ignore the faulty CTS signal and default to "cold/safe rich"
detobias is offline
post #19 of 25 Old 02-26-2013, 11:46 AM Thread Starter
Ok, i am probing the cts right now at the LM...fan kicked on at0.68 volts which is way below any values on the charts.
post #20 of 25 Old 02-27-2013, 06:27 AM
Just A Guy
NAJ's Avatar
Why not backprobe the CTS connector?
post #21 of 25 Old 02-27-2013, 06:59 AM
Just A Guy
NAJ's Avatar
Also, 84 electronics are different than 85-up so it is possible the 84 CTS has a different voltage output.
If you have low vacuum that needs to be repaired first.
post #22 of 25 Old 02-27-2013, 09:14 AM Thread Starter
I probed at the LM and the sensor. Same readings, all under 0.8v
Where do i find the 84 specific values?
i am hoping the low vacuum is being caused by a sensor or injector issue...I have been using propane to searchfor vac leaks, and have found nothing yet.
Edit: Looks like this particular engine uses ohms for cts operation...more like the GM and Ford systems I am use to.
But it makes me wonder how i was getiing 5.5v when I started testing, and it all went out the window when both wires were hooked up.
post #23 of 25 Old 02-28-2013, 06:28 AM
Just A Guy
NAJ's Avatar
The sensor values I gave you were from a Chrysler Training Manual and from my 1990 Daytona VNT and my Son's 94 Sundance Duster 3.0L.
Without seeing a known good 84 I would have no idea what the actual CTS voltage should be.
It does not use ohms to transmit engine temp data to the controller. they only use ohms for diagnosing the circuit.
post #24 of 25 Old 03-02-2013, 12:24 AM Thread Starter
Hey fellas...the ASD Rlay, is that the one in the pass side kick panel near my map?
post #25 of 25 Old 03-02-2013, 07:17 AM
Just A Guy
NAJ's Avatar
PM being sent.
Human Verification
