Wire identification on (blue) LM plug tII 87 Shelby Z - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo Dodge Technical Chat > Engine Management, Fuel, Spark, EGTs, and Air/Fuel Ratios
Old 04-10-2013, 05:17 PM   #1
Garrett Booster
My Ride: 1986 TurboZ
Engine: 2.2 135ci
bebturboz is keeping the peace
Guys, someone cut the wires for the plugs into my logic module! Why on Earth they would cut them, i have no clue. I need schematics or a way to test which wires go where or... something. The red plug is sorted out. I got to the blue plug, and there are a few wires of the exact same gauge and color combo. This is somewhat good for me to have found possible wiring issues that the previous owners may have made, but how in the world do i find out where they really go???
bebturboz is offline
Reply With Quote Quick reply to this message Share on facebook
Old 04-10-2013, 05:21 PM   #2
Re: Wire identification on (blue) LM plug tII 87 Shelby Z
- OFFICIAL GEARHEAD -
My Ride: Ram HFE/Omni/SL/XR7
Feedback: (100)
detobias is keeping our cars running
bookmark this:
MiniMopar Resources
this is the page 86 TI:
1986 Turbo I Logic Module - MiniMopar Resources
Pin Circuit Wire Gauge Wire Color Function
1 K6 18 OR/WT* 5.0V power supply to TPS
2 J11 20 RD/WT* Direct battery feed (via power module)
3 N13 20 DB/OR* A/C cutout relay output
4 K3 20 BK/PK* Power loss lamp output
5 K1 20 PK/BK* Canister purge solenoid output
6 S6 20 GY/YL* EGR solenoid output
7 K9 18 LB/RD* Power ground source from fuel rail bolt
8 K9 18 LB/RD* Power ground source from fuel rail bolt
9 - - - Not used
10 - - - Not used
11 C2 18 BR A/C damped pressure switch signal
12 S4 20 BR/YL* Park/neutral safety switch signal
13 D40 18 WT/PK* Brake switch signal
14 G7 20 WT/OR* Speed/distance sensor signal
15 - - - Not used
16 - - - Not used
17 Y7 18 TN/YL* Fuel injector sync sensor signal
18 N11 18 BK Oxygen sensor signal
19 - - - Not used
20 K22 22 RD/BK* Battery temperature sensor signal
21 K7 18 OR/DB* Throttle position sensor (TPS) signal
22 J11 20 RD/WT* Voltage regulation sense signal
23 K10 20 TN/BK* Coolant temperature sensor signal
24 N12 18 BK/LG* Detonation sensor signal
25 K13 18 BK/RD* Air charge temperature sensor signal
detobias is offline
Old 04-10-2013, 05:24 PM   #3
Garrett Booster
Engine: 2.2 135ci
^^^ Oh wow, that's awesome info man! Thanks a bunch for your quick response. I'll look for the tII info on their page...
Old 04-10-2013, 05:29 PM   #4
Feedback: (100)
detobias is offline
Old 04-10-2013, 05:31 PM   #5
Garrett Booster
Engine: 2.2 135ci
Originally Posted by detobias View Post
Holy crap... this site is awesome!!! I gotta say thanks again! :)
Old 04-10-2013, 07:30 PM   #6
R.I.P Dennis Jarvis
CBMDennis's Avatar
My Ride: 1988 Labaron Convert
Engine: Turbo 2 2.2 liter
Feedback: (29)
CBMDennis is keeping our cars running
BrandonI foresee a lot of reading and printing in you future. While your at it you might want to download your parts catalogs.
ServiceManuals
Dennis
Last edited by CBMDennis; 04-15-2013 at 05:41 PM.. Reason: corrected 'parts catalogs"
CBMDennis is offline
Old 04-10-2013, 08:15 PM   #7
Moderator
Jakecs's Avatar
My Ride: 1988 Daytona CS
Engine: 2.2L Turbo I
Jakecs is ready to make a name for oneself
Those are just parts catalogs.
Jakecs is offline
Old 04-15-2013, 05:09 PM   #8
R.I.P Dennis Jarvis
CBMDennis's Avatar
Feedback: (29)
Jake It's hard to get a partsvoice.com ***************** or wholesalemopar.com without the information in those 'parts catalogs'.
Old 04-15-2013, 05:19 PM   #9
Moderator
Jakecs's Avatar
Yeah I know, the parts catalogs have been an invaluable resource to me, but I was just correcting, but for a second I thought I was dreaming when you called them service manuals. It'd be awesome if they were online somewhere.
Jakecs is offline
Old 04-15-2013, 05:32 PM   #10
R.I.P Dennis Jarvis
CBMDennis's Avatar
Feedback: (29)
I have joined ALLDATA and MITCHELLS and even if you combine the two they don't have as good of information that is in my factory service manual.
Old 04-15-2013, 05:57 PM   #11
Moderator
Jakecs's Avatar
Which is why some like myself should scan my entire factory service manual.
Jakecs is offline
Gear in this thread - Powered by O'Reilly Auto Parts
First Name
Please enter your first name. Invalid names will result in account termination.
Location
Where you live
Insurance
Please select your insurance company (Optional)
Ride
What do you drive?
Human Verification
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
