Old 05-06-2004, 03:27 PM   #16
MAP cut-out raiser from www.dawesdevices.com
Old 05-06-2004, 07:34 PM   #17
Yes 2bar map, and 20+ injectors, base fuel was set at 43PSI.
Just make sure you don't lean out, watch your EGT. I didn't have a EGT at the time, but with the head off it looks fine. Was still rich in the top end. Down low I was REALLY rich. I wouldn't bother with a cal for 20+, just a waste of money.
Originally posted by unclejemima
hey "87Shadow", were you running a 2bar map and 22psi? How did you do it safely?
-mark
Don't get a Map cut out, you'll have to dial it in for different altitudes. Just use a Zener Diode (4.7V) and you'll be great. I used that to trick the computer, and a boost controller to up the boost.
87Shadow is offline
Old 05-07-2004, 11:56 AM   #18
Hmmmm, interesting, I am at sea level, have gone up the mountains snowboarding and such and never had a problem!
Old 05-07-2004, 12:50 PM   #19
A Few Comments
My Ride: 86 Turboz CS,
Engine: 2.2 T2
The combination of injector, computer, boost.
The early LM can tolerate the larger +20's and compensate for idle,part throttle etc. So poeple with 2.2's converted can run an "equivalent" GLHS Stg 2 module and live happy with the +20's without
playing with fuel pressure to compensate. Best move is to get a stg 2 GLHS and have the overboost eliminated by the computer programer. My 86 has one and runs great.
The later 88/89 Smecs and the 90 SBEC's your on your own. I have been told without a custom cal, they dont like having the larger injectors. The ywill run pig rich and idl;e for crap. I dont see how people turn down the FP(for idle)to run the larger injectors at higher boost, defeats the purpose?
THe 90+ SBECs are even more difficult to program and there doesn seem to be a lot of folks running them.
Anybody have a SBEC Cal on a 90+ 2.5 with good results??
Mike
Turbozcs2003 is offline
Old 05-07-2004, 12:56 PM   #20
Re: A Few Comments
It doesn't defeat the purpose as you don't drive around the city at 20-30 pounds of boost. I have my boost set to 12 on the street and the fuel pressure around 30 psi, it runs great, lots of fuel and still gets 14-18 mpg depending on right foot mode,
It takes 2 minutes at the track to turn up the fuel pressure!
Old 05-07-2004, 01:29 PM   #21
Aaah!
Engine: 2.2 T2
Well why not run the stock injectors and 30 MPG and turn up the fuel pressure to 60 PSI base at the track???
14-18 around town is terrible. Have you done an oil analysis on your van?? I bet your loaded up with fuel in the oil. Your wear rate on bearings and rings will be very high.
My dilemma is getting a good cal for my 90 Daytona to run the 3 bar Map and +40's. I really dont want to have to resort to playing with the FP.
Mike
Old 05-07-2004, 01:49 PM   #22
My Ride: 1989 Turbo Mini
Engine: 2.5 Mitsu Powered
Hell I run 18psi on a stock t2 with nothing than a blow off valve(1g) and two bleeds. I also have a cone filter on it also and thats it. She has 147000 some odd miles on it. No extra fuel, stock intercooler, and the **** thing still has an overheating problem and has been my daily driver for a year, and I am not light on the gas.
cletis234 is offline
Old 05-07-2004, 01:49 PM   #23
I drive a MINI van, there pigs on gas. Did a survey on here and thats normal for turbo vans My oil is clean and my engine has now over 20,000 km's, and passes emissions test no problem. 30 mpg in a mini is **** near impossible.
I did run the stock injectors till this year as at 18 psi they were maxed out and I needed more fuel to run faster. I had the return line blocked to run the necessary fuel last year. Now I have the 255 pump and +20's.
Old 06-13-2004, 07:24 PM   #24
so am I able to run my setup without the +20 injectors and have my boost to 15psi almost all of the time without any problems? ... wont that be running to lean?
BUT if I am to put in the +20's I have to do something else... so would the fuel pump mentioned by turbovanman and a A/F gauge be sufficient or do I need something else... like the calibration to my computer ?
iloveshelbys is offline
Old 06-14-2004, 12:13 PM   #25
Every car is different. You will have to check your air/fuel with 15 psi. If its lean, then you will have to add cold starts which make daily driving hard or get +20's and a afpr as well as a custom cal as 20's with stock fuel pressure will run rich for daily driving, unless you turn back the fuel pressure but then you will be lean, doh!
Old 06-20-2004, 02:35 AM   #26
i know this is kind of back from the dead but turbovanman when you run that much boost ona the +20's what do you set your FP at? im working on a new theroy on how to run my +20's with a 3:1 RRR. if you told me were your fuel pressure I would have a better idea if it would work or not.
also how much boost? i need to know to do some math...
TurboShadowES is offline
Old 06-20-2004, 10:54 AM   #27
My Ride: 2003 Silver SRT-4
Engine: 2.4
Why dont you guys just add a extra injector when it starts to lean out?? This is what my plan is... crank up the boost untill it starts to lean.. what 15-16lbs.. .then just smack in a extra injector right in front of the TB. No messing with FP or injectors...
FrankNbeans is offline
Old 06-20-2004, 11:51 AM   #28
My Ride: 1987 Shelby GLHS 189
Turbozcs2003 has a good grasp on thngs... Vanman.. I've said this before, I have no clue how that 2.5 of yours stays together. But it does Not great to tell everyone what your engine has done, unless you put the caveat there. 99% of the folks who try what you are able to do will have ashtrays.
Aside from that, I am very puzzled. Why would you buy +20's and then ask what to do. Granted you need to know. But doesn't it make much more sense to have a clear path charted BEFORE you buy the parts??
glhsken is offline
Old 06-20-2004, 11:52 AM   #29
"Being a man takes lots of Drinking,Shooting, Hummping and Horring.........more Drinking.......and horring if there is time!"
Yo Jeremy... horring is spelled with a "W"
glhsken is offline
Old 06-20-2004, 12:52 PM   #30
simple....i got the +20's brand new for a good price and since my plan was to run 14-15psi ..why not buy them
MPAA | Credit Cards | Hotels | Loans | Magazine Subscriptions
