It does look like not enough fuel. It does appear that the old FPR was not working well. With the old one I could get lots of knock (was not all the time). With this new one (set @55psi at idle), so far, I have recorded no knock. That is with increased boost levels. Today I will try to put the timing back to 12, maybe even 14 if all goes well.
The old one I had tested before. I put a fuel gauge on and at idle it was 58psi. I even had a garage double check it with theirs when the car was boosting and the pressure was going up accordingly. Of course when they tested it, no knock was recorded. With that info, I did not think it was bad. Recently, I thought I smelled gas in the FPR vacuum line, but it was very faint.
I had been getting the odd code 13 (fuel in the vacuum lines??), and that is with new baro/map, and vacuum lines. Other driveablity issues such as hard starts sometimes, bad baro like behaviour, and acceleration issues. Since the new AFPR none of these have reappeared.
Yes, I have an A/F. It does seem to read richer than before. The data logs diffinetly read better. The O2 readings are much higher than before. I had .92- .96 before and still showed knock. I see 1.02 .98 now. The O2 pattern appears different now.
It is only the second day, so I may be jumping the gun, but I hope not!
Scott
88 Daytona Shelby Z
www.sheenconsulting.com/car
